just ordered a turbonetics te44 bb from cottons, gasket set , adjustable actuator for $1025.00 to the door
im not sure ,it comes with a copper set, as long as you keep helping it will make it to ohioWhat gaskets are included with your gasket set from cottons?
sorry should have said ya"llim not sure ,it comes with a copper set, as long as you keep helping it will make it to ohio
yep , doug stone too
Yeah and Jerry Reed of Smokey and the Bandit fame was born in Palmetto, Ga. Most of the movie was in Jonesboro, GA about 20 minutes from here. I guess we should start a new celebrity thread. LOL.
Believe it or not Allan Jackson and Doug Stone are both very home town, down to earth, people. If I knew them peronally and asked them to be there, I think they would. Alan would probably ask for donations to Angels House, which is a charity for battered women in Nenwan, Ga, that his wife Denise is a big sponsor of.Well hell! Have Alan Jackson and Doug Stone come on up to the reunion! We'll give em a spot in the Jegs suite too!![]()
nope , you are seeing it right, moved at some point for reason, have a lot of paperwork showing the first owner having problems early on with this carIt looks like your intake has been off at some point.
It also looks like your wastegate solenoid is mounted to the injector? I have to be seeing that wrong.
the wastegate solenoid is mounted to the intake , right over the injector , who knows why.in other news i found a packing list from PVL , INC , royal oak , michigan , for a trans am kit , dated 10-3-89 , interestingIt looks like your intake has been off at some point.
if i am understanding you right, the two gaskets i have pictured go together , which means there was no gasket at all on the 3 bolt collector , what affect would that have if anything ?You've got no worries here...you just need the flat 3 bolt header collector style gasket(which may come with your new turbo) and you need the lead donut gasket that 8289ta showed you.The donut goes inverted in the elbow with the lead portion facing down into the downpipe. It may come apart like yours did, even when new. The installation of the 3 bolt collector gasket is self explanatory.
And of course the oil drain gasket too needs replaced.
thanks , they have a lot of nos parts with reasonable prices as wellHere is the 3 bolt gasket that WS6 is talking about, I got mine at nos4gn.com
http://www.nos4gn.com/servlet/the-699/grand-national-copper-turbo/Detail
Rob - I think the downpipe and the header each get a gasket.if i am understanding you right, the two gaskets i have pictured go together , which means there was no gasket at all on the 3 bolt collector , what affect would that have if anything ?
Also you are going to need a new turbo oil drain gasket:
http://www.nos4gn.com/servlet/the-89/Buick-Grand-National-parts/Detail
