RatFink
TORQUE
it has a adjustable wastegate and i did get it to move, took a good bit of effort ,is the ta-49 a turbo ? didnt see it , if not , what turbo would you recommend ? thanks for the info and link
What are your modifications? Prescision Turbo and Turbonetics are the leading turbocharger manufacturers. there are others like Mitsubishi and Garret, but in the Buick world the previous mentioned are the premiere turbos and used most widely. The Prescision turbos use the ID TA to denote "Stock Appearing" so that it "looks" stock. Some people want to stay stock looking. The negative is that the stock garret design has a smaller compressor intake. The other ID is TE, this stand for modified or wider freer flowing intake on the compressor.
So basically the popular slightly modded tried and true turbos since about standard1995 till now is the TA-49 and the TE-44. Same internals but the difference is in the intake. I had a TE-44, great fast spooling turbo. Works great with stock to 42.5 lbs injectors and stock downpipe and convertor. I'll post a pic below of the differences.
Now, if you want to move a little faster, you can go with a slightly larger compressor side, like a TE-60 or a 6262, I have a CPT-61 currently that works great with my 2800 NON-lock convertor. Spools lightning fast. It uses the new-ish ball bearing tech instead of standard journal, so this helps with the friction inside the turbo so a larger wheel can spin with the same amount of exhaust energy. But I recommend a 3" downpipe with this. The advantage to BB turbos is that you can keep your convertor "tighter" like 2800 rpm range this helps keep your trap speed higher than if you used a 3200 stall convertor with a standard journal turbo. Make driveabilty nicer and close to stock. Fast spooling turbo and responce. If you get to big of a standard journal 60mm or bigger turbo you'll need a 3200 convertor to spool it up, then losing just a bit of top-end and it will also have a slushy feel when cruising around. Lot to think about in turbo selection and supporting mods.
Some info for you: http://www.turboneticsinc.com/node/196
