Mike Arrigo
You can try Caspers too. They have some cool stuff for our cars and John is a super nice and helpful guy. Specializing in automotive interconnect and wiring systems
it looks that way, but anyhow im grinning like a dog with 3 dicks! :WOOT: :dance:So - I guess the chip and injectors needed to be installed together?
working on it now, mainly waiting on a clown to ship the pod,(ordered it sun) this is the last thing i will order from this dip-sh@t :whistle:Did you get the boost gauge in yet?
are you talking about a powerlogger? if so julio said to get one so he can dial it inIf the air/fuel ratio becomes excessively rich, it can drown out the engine with fuel and actually put the "fire" out - especially under idle and low speed conditions.
A high flow injector has a larger "hole" than a smaller one. So more fuel flows through it per pulse. If you increase the size of the injector, but do nothing to change the programming to shorten the injector "on" time, the engine will run too rich. So to maintain the optimum A/F ratio that makes the car run well at other than wide open throttle, the computer has to shorten the duration of the injector pulse.
To change the computer programming in your case required changing the chip. If you don't have a wideband O2 gauge, you probably should buy one to make sure that your non-stock programming is working well.
okay guys , what if anything do i need to buy, i have read this about 20 times and i think i understand, but not sure, since i am a rookie, give it to me in laymans terms, thanks for your help, you guys are smart as hell ,yall could do this for a living. :yes:No, he's talking about a more accurate O2 sensor. A power logger is a data logging tool you install as a piggyback on your ECM and monitor or log data in real time.At this point the WB would just be a spectator and maybe too much information. Besides, without using a PL and an updated Scanmaster he wont be able to view real time WB O2's unless he installed a Brand specific WB gauge.
It's my opinion that at this point Robert can do well with just his narroband O2 and TT 5.7 chip. His adjustability is limited to PE mode anyways and overall fueling and the 1-2 gears.
Eric's got a really,really good handle on the use of the Motoron 60# in his chips.So I wouldn't be the least bit concerned with the chip's programming during normal open/closed loop operation.
thats what i was thinkingI think WS6 said you should be good to go with what you got!
Rich's info is great.
Our 20 year old chit is plenty fast enough... I'm running Eric's SD chip and love it!
basically what im getting from all this is me, and a lot of other people are spending alot of money , time and effort to get this cars 1-2 seconds faster than stock, but its still fun :yes:It isn't plenty fast enough. It is doable though.
Please, don't spout off info about SD tuning until you run your car down a track.
as long as it will run in the 12 sec range and stay together im happy, i drove it yesterday and the guy beside me almost slammed into the back of a car looking at it, funny as hell :jaw:A lot of money is relative. You'd be spending two or three times more money purchasing, installing and programming a stand-alone system. For what you're doing, the GM computer and a chip can handle it as long as you are using a high impedance injector. Most of the larger injectors (beyond 60 lb) are low impedance and require more drive current than an unmodified GM computer can deliver. Even so, some guys have modified the GM computer by changing the output drivers to push out more current.
