Would the 88 GTA one work. Seen a complete set of tail lights and center filler on eBay for $219.00
I still have the turbo emblem at the bottom. And I would have to just sell the light's
That filler panel will work, but the red reflector has to be removed so the turbo strip can be put on. That reflector is hard to remove, I think I used a heat gun to remove one.
I think we posted pictures and details how to turn the regular style filler panel into a TTA one ... not searched for those posts but should still be on here.
Hard part as Mike mentioned is to remove the heat glued red reflector part; you need that surface perfectly flat before applying the turbo strip or it will show due to the thickness of that strip.
