robert lee
Gold Member
Torque strap's ?
put a motor plate and mid mount in car lolTorque strap's ?
I have a turnbuckle style on there now, figured it was better than nothing..Robert,
Here's an attached picture of one style of anchor that I made. I used a turnbuckle instead of a ratchet strap. It worked well and I adjusted it so it just "loaded" the driverside. It worked pretty well, but I always was suspicious that it caused false knock.
I eventually went to a ratchet strap for awhile too.
Then I went to the H&R mounts and solved the problem alltogether.
Thank's Rich, how far did you have to jack the motor to change them? I'm starting to i will have to put wingnut's on everything:crazy:
BTW is that strut tower brace made for a V-6 ? i thought they installed different from your pic...
x2 the ones ive seen actually attach to the strut tower ? look like this one could damage the fenders ?
No, that's how they install, that whole area is the strut tower,double walled and all.
It ties the front sheetmetal cage together...been running one on the convertible since I've owned it.
Ironically I've removed the one from the TTA and left it off as it was becoming such a common thing for that motor to come out.....how sad is that?
u ever heard abt third gen k members messing up struts ?
