Valve springs
No cup's. It's a cup that goes on the bottom of the spring and will raise the height if not taken out.
Joe
cups? I'm sorry im to familier with vavle springs..so take the ones out on my original springs before dropping the new one in?
Kirban use to make a tool that worked well.
What tool are you using?
Make sure you tap the retainers a couple of times before you hit them with the tool to loosen up the keepers. Just tap them lightly, you don't want to drop a valve!
The installed height is 1.725.
Joe
I dont want to mess anything up so im just going to take it to a shop and have them do it..
I used the 981's with out any issues. 980 is the proper spring for the stock cam. Aftermarket flat tappet would work well with 981. But 980 is your best choice.
joe
