Turbo Tweak INSTALLED !!!!!!
TurboJoe89TTA
TurboJoe
WOW, what a great chip. I was going about 15 mph and I mashed it and the tires broke loose. Better start up too! Better everything!!! Spools up fast. Lot faster than the Thrasher. I should have listened to you gentlemen earlier. I need to dial it in now. I can probably turn the boost up to 17 lbs. I am at 15.5-16 now with NO KNOCK. Also, that thrasher killed the gas!!! This chip is AWESOME !!!!
I have the Accufab. adj. fuel regulator , Caspers Volt Booster , K&N , no CAT , Hooker Cat-back . Pretty much it. Thanks again.
I totally knew you'd like this chip MUCH better! You're like me, sometimes you just need to learn the hard way! Nice job, and glad you like it!
Mine used to do the caugh sputter right off idle ... after the installation of the Turbo Tweak Chip ..... the streetability is bar none the best, I have a Alky Control Kit and a scan master, hot wire and 40lb injectors and run a best of 13.3 @ 105 mph @ 20 lbs boost, on the new chip,blows the tires off of the car for the first 100 feet, I'm also am sitting @ 4400 feet above sea level, sticky tires and we're shooting 12's, all the GN's here in Calgary run Turbo Tweak chips, can't bet them !!!
you will LOVE that chip !!! have fun with the mods.
We need to schedual a meeting of the TTA website sometime, somewhere central, so us Canadians can join the fun !!
I'd love to meet all of you and see you TTA's, as I'm the only one who drives mine here, and there are 3-4 of them, including mine, and I have never seen another one here !!!! I LOVE DRIVING MINE !!!
