Turbo out of order
That can be fixed if all you got is a blown headgasket, I did the same thing at one time. If these cars are run hard and you have knock, it will eat away at the headgasket and they will blow.
I hope it is not worse or debris getting in bearings in the lower end! Good luck, but a headgasket is really not a big deal.
Yep I hope there is nothing else wrong, will know about it tomorrow. If it is just a head gasket to replace it is not that bad in the end.
Well they open the engine and now I know what is wrong with it. Just have a look.
So I am looking for a piece to replace it. Cylinder Head gasket right ? (not so good with technical english)
ouch. hope the gasket is all you need!
Damn, I feel your pain ... hope nothing else been damaged.
Remember the original head bolts are torque to yield and can not be re-used so you need either new original style bolts or go with ARP bolts that can be re-used (I would recommend this route).
There's a post on the forum with regards to the correct length ARP bolts (and washers) to order, you will also have a bit of interference with the headers as the head/washer is slightly higher/larger than stock so header flange will need to be cleared (just file a slot for each head bolt and that's it).
At least there is no milkshake, follow the correct pattern when tightening bolts. Octane starts to go away in 2 weeks so use fresh gas as much as possible.
