stock TTA parts
TC Turbo
I'd like to grab some of the stock parts my car is missing in case the day ever comes that I decide to restore it to original. Since I'm in the midst of buying the extra parts the guy I purchased the car from has I can't spend a ton of dough right now but thought I'd post in case it takes a while to get a response or somebody has some of these parts relatively cheap. It could happen!
Anyway I'm interested in a stock downpipe, cat convertor, injectors, fuel pressure regulator, and most importantly the air cleaner hose and plastic elbows. I have a Buick air cleaner which I understand is the same except for the plastic elbow and maybe a bracket? So I should be set with an air cleaner but need the hose assembly.
I do have a set of Buick injectors too so if they're the same I'm probably good there too. So whatcha got for sale guys?
I would think that a nice stock down pipe would cost as much as a 3" modified pipe. Some fabricators out there may make 3" DPs for the TTA in the future (or even a f-body with a buick convertion) but stock pipes will never be made again. Once there gone, no more. I found one for a friend's project f-body, that has since been called off. I can't believe I located one. I paid $200 for it a while back.
has a little bit of surface rust only
