tta299
White Car Fever
As the title reads I had been spraying alot of alky with a power plate. when i took the plenum off i noticed the back cylinders in the intake were alot cleaner than the front ones. this leads me to think the plate a restriction when using alot of alky ? Or the back cylinders getting more because of the bend the air an alky have to make ? Im going back with a gn1 spacer an ditching the plate for now. Spare engine has already been through with bearings an rings roller cam and dls front cover an oil pump wich is a very trick peice ... u can adjust oil pressure from the outside of the cover
