procharlie
I have TTA #162 that had been modified extensively before I got it, including a beefed-up trans and 3.42 rearend from a GN. My speedometer reads quite high, about 15% too fast as well as I have been able to measure. I thought it might be that they didn't change the speedo drive gear when the rearend was changed, so I pulled the drive gear from the trans and found it is essentially the right gear for that rearend/tire combination, maybe one tooth off but that would only be about 3% error. But I did find that this car has an electronic speed sensor, not the speedometer cable like the GN has, and when searching online I found someone who sells these electronic speed units and they have the ability to be adjusted for changes in rear axle ratio, tire sizes, etc without fooling with gear changes.
SO, my question is does anyone know if the TTA came with this electronic speed sensor standard, and can it be adjusted to make it read the correct speed? I can't figure out how else it could be reading so far off. DontKnow:
I'm new to this forum but it looks great, and I am hoping you can give me some help. When I get my car checked out better I will let you know how it performs.
Thanks,
Charlie
Thanks,
Charlie
