Guss23 Active Member Mar 24, 2014 #1 My reverse lights don't work. Is there a switch?? Where is it?? Do they fail commonly??
pont1230 Well-Known Member Mar 24, 2014 #2 Have you checked the bulbs.I think the switch should be under the center console by the shifter somewhere.
Jan Larsson Administrator Staff member Mar 25, 2014 #3 If you have the 1989 Firebird service manual you have the electrical schematic there to help figure it out. Switch is on the gear lever, should be a fuse as well if I remember correct.
