This is a sample guest message. Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
Replacement Power Antenna
BOBTTA#464
Hello All
After replacing my power antenna mast assembly this past weekend on my 88GTA, and paying $115 for it, I got some information from a member on that other site that I thought I would share with all.
Below is details of a EXACT MATCH OF ENTIRE UNIT for our cars available at Auto Parts Warehouse.
It is listed for a Jeep Grand Cherokee, years I believe is 88-92. This was when Jeep was changing from American Motors to Chrysler/Dodge. They used the same assembly as the 82-92 Camaro/Firebirds.
This unit is a direct fit with relay plug, antenna cable,and fender grommet.
It is available for $78ish.
http://www.autopartswarehouse.com/sku/Crown/Antenna/56003151.html
Check it out. I hope it helps out. I bought two and they will be here
tomorrow.
Spare parts and all is a great thing.
Have a great day!
Bob
Good find, let us know how they do compare to the OEM antenna.
It looks spot on; if you can compare the bracket location that holds it in place (looks different) and the overall length.
Antenna cable looks shorter but that can be transferred over from the OEM unit so not a big deal.
Let us know what you think and how they compare once you get them.
Thanks for sharing :thumbup:
Good find. I found a complete OEM unit NOS in the box that I bought as a spare, but it would suffer the same fate if used so I would need a new cable anyway. Ultimately the best solution is the steel cable as detailed elsewhere on this site. It seems to have held up good so far.
x2 - Yes, please.
Yeah dude, you need to take start to finish pics, i need to be edumacated on antennas... especially how it comes out the fender...:devil:
good find thanks for sharing,they have a write up on turbo Buick about replacing the plastic cable and putting on the steel cable if I'm not mistaken on the turbo trans am section
Yep, I wrote it and supplied detailed pics. Let me know if you have any questions. Total cost was less than $5 provided your motor and mast are fine, which they normally are, it's that pesky plastic weed eater wire inside that breaks.
OK Guys and Gals. I received my two new replacement antennas yesterday.
They WILL work! YAY! The length,size, 3section mast, motor assembly,and mount tab bracket is identical.
There is two differences though, no biggie.
1. The antenna cable is shorter than original, but just use your old one
2. 3 pin Power connector is shorter than original, again, add to it.
Below are some pictures for comparison.
I did not take pics of my original installed in my car because, well, it's installed.
Mine still works fine but the antenna cable has a bad end on it where it plugs into the radio. Is the cable replaceable and if so where can I get one? I have searched for a couple years unsuccessfully :(
Scott
I have replaced antenna cable ends before by using a new end available through Radio Shack,Digi Key, or Moser Electronics. If you can solder, your in!
Scott
I have replaced antenna cable ends before by using a new end available through Radio Shack, Digi Key, or Moser Electronics. If you can solder, your in!
That's what I was hoping to find but I haven't had any luck finding the correct cable end for the factory radio. If I recall there are 2 different sizes (big and small...old style , new style) can't remember which either off hand. Soldering is no problem...been doing it for a living for the last 30 years...NASA certified too along with a bunch of others :thumbup:
Reviving another old thread. Did the replacement unit from auto parts warehouse come with correct bezels/grommets as well as chrome nut? Looking to replace the into on my TTA's exterior with the correct specimen.
Thanks
Vito,
Did you ever find the correct bezel/grommet? I bought this antenna recently but haven't put it in yet. Maybe when it warms up outside.
Thanks
Fabio...been off the forum for a while. Yes I did... In fact the correct one was already installed on my car. Found the original receipt from the dealer. As luck would have it, the original owner was a TA enthusiast and made sure the correct OEM parts were used. You can I am pretty sure use any GTA/Firebird power antenna grommet / bezel. Feel free to email me directly if you need pictures or what have you. [email protected]
Hello All
tomorrow.
Have a great day!
Bob
Is the 56003151 number a part number. ? My computer isn't coming up with anything. Tks
Hello All
tomorrow.
Have a great day!
Bob
link goes to site---doesn't work when on line. is there a phone number for this group? thanks #904
i told you the part no longer exists ,
post was made 11years ago
if you try searching the crown part # 56003151 youll find ..its gone
found one crown antenna (last one ) not cheap (in saudi arbia)
link given--doesn't work--any suggestions?? tks #904
I see one choice that for the 1990 Jeep Laredo for about the $77 you mentioned--but numbers not given -- am I on the right track. is there a brand?? thank you
i dont know why i post
only track to get a crown power antenna 56003151 is from the saudi guy
why dont you just rebuild the one you have , unless your mast is bent it is rebuldable the cord kit at theantennasource.com is 40.50
when you get the fenderwell out of the way---take pictures with flash to get positioning. With the antenna down--have to pull the unit down and tip it out. if the antenna is up?? have to attempt to power the antenna to retract---apply power to unit white wire. have fun you get used to it--those 2 screws are a pain.
