Radio
bimmerzhp
Not sure if this is in the correct location. I noticed that the time on my radio stays on all the time. Is this normal? I thought it should do out after the car is turned off. One other question, what is the temperature range she should run around? All stock 8K miles. Thanks.
It's not normal for the clock to stay on.
As for temperature, my car runs around 200F. If I'm correct, the gauges are set up to run normal in the middle of the gauge. The gauge is not all that accurate either, get yourself a Scanmaster and check the temperature that way.
Whats the fix on the clock always on? The radio itself is broken, or someone wired an aftermarket wrong then put in the stock radio? hace the same issue, but no radio right now.
As far as the engine temp. goes. The Scanmaster on the hottest days cruising speed about 182 degrees and a little warmer in stop and go, red light traffic. That is when you need the fan mod to make both fans run all the time.
I think you just answered your own question Marcel, glad it's about ready to go, take the whole family out and have fun...
