First of all I want to thank Julio for all the help and advice he has given me. Best customer service ever. The alcohol was pretty much straight forward except for losing a gallon of alky when I didn't tighten down the pump fittings...
Here is a picture of the overflow and nozzle.
And here is one of the LED's
And the controller...Thanks for hooking me up Julio!!
Here is a picture of the chip extension so you dont have to drop the ECM to get the chip out. Makes it real easy to change.
The powerlogger was also simple to install. After trying to figure out why it didnt work it came down to a bad ecm. I had an extra so I used it first...I guess that is why I got it free. The car started with it though?
Anyway, after replacing the ECM, it works like a charm. Since I had already run the map wire into the interior for the PAC alky, I tapped off that for the boost sensing. Very nice deal. I ended up running it under the console and have it come out right under the seat. Can be tucked away for passages and easy access for the laptop.
Screen shot...
As soon as the alky chip gets here, I will tune some more. So far up to 20lbs and no knock at all. Used to get huge numbers....
Jason
Screen shot...
Jason
