I shut my car off last fall at a gas station, got back in and turned the key & nothing. Thought I had a dead battery that was not the problem.
Calleda a tow truck and he said it must have something to do with alarm sys. He said turn the key forward and I'll start it for you I didn't believe he could, he proceeded to open main wire harness in engine compartment (drivers side). he found a blue or violet wire small gauage and by using a jumper touched it to the input side of the altenator. It started no problem ...I couldn't believe it!!
I am still stumped as to why it won't start via the key. This is what I done so far:
- changed ign switch
- removed alarm system
- had 2 mechanics look at it and they say they don't know why it won't work either and offered to run new wire. I passed on that cause I want to stay orginal.
I really need to get it working the way it should be. If any one here has had this problem or has any Idea on how to fix it I would appriciate it.
You can email me direct at [email protected] or just post a msg here.
