Jan - do you have a part number on those?
OUCH!!!
Jan is this the same bolt I need for the top of the radiator:
i have alot of these if you need someJan is this the same bolt I need for the top of the radiator:
This one even looks a little like it. I think I am going to take one for the team here and order them. Hopefully it is an alternative to the other clips.
25 Cowl Vent Nuts #6 Or #8 Screw Size GM 15596280 | eBay
Jan - one more thing. What is the correct part number for the door panel clips? I want to order some from the same place.
Looks damn close, wonder what the dimensions are and how they compare to the original nuts ... you plan to order some and compare?
Jan - not only do they snap in place, they are a better design. They are solid, not like the old ones with the split down the sides, so they do not crack when you put a screw in them. They are more of an oval then round when you look at them from the top. But it fits very well. They snap in place because of 2 nubs on the sides, and they stay tight. If you want 4, I'll send them to Jim so he can send them with your T shirts.
