tonysturbo
It will start and idle fine for a few mins and then run rough. You can drive it but when you shut it off it won't restart for a while. Then it will start again..I'm thinking its the crank sensor. I've already checked fuel pressure and its fine, changed IAC, new O2 sensor, new plugs, set TPS Any other suggestions before changing out the crank sensor.
