New hoses and clamps
Quiky One
Silver Member
Finally got off my bum and installed the new hoses and clamps. This hoses is very tight stuff and I had to use liquid soap and a heat gun just to get them on. PITA but it looks good and the uppipe didn't pop off.
I just need to put the turboshield on, wipe down the chrome, install my new plugs and wires, and it will be ready for BG.
Sweet Bro! Looks like you have your cut-out pointed in a good direction as to to not burn the floorpan up. So you didn't have to make a turn-down. Did you add a driver's side valve cover so to have another breather? I didn't notice it on your motor from earlier posts. Cool. :burnrubber:
I would have added a turndown (and still might) but the studs on the ypipe aren't long enough and I was to lazy at the time to cut the original ones off and replace them. Cutting an 1/8" at a time is very tedious...
Two drivers side VC's. Good eye. :thumbup:
Damn Jason I thought I taught you everything! Turn those t-bolt clamps down! Gotta make it look like you took your time and took attention to detail! :) Look at my t bolt clamps on my GN's engine bay...
I turn all of mine up and facing the same direction like you could go down the line at the factory and just hit them all real quick with an air ratchet. Just as long as they all face the same direction and are level I think it looks just a good either way.
Looks good Jason, too bad it's not making enough power to put them to use.
I started to do that but there wasn't room on one of the MAF inlet pipes and I didn't want to fight. I'll give ya $10 in BG to do it. :chair:
I do like the clean look, but like Jared said, it is uniform.
