WS6
Stay thirsty my friends
So I swapped the upper column from an automatic column to the 5 speed column, in effect just getting the detent cable feature and such.
I swapped the upper guts including the turn signal switch, wiper ring etc. And for fun I hooked up the battery to be sure the turn signal and radio controls still work.
Everything works except the horn, as soon as I hook the battery up the horn blows continuously....even without the steering wheel on it. I've narrowed it down to something in the column and I even pulled the cancel cam switch all the way out and I see no break, or short in the black horn wire.
Is it possible I damaged that cancel cam switch with the 4 post wiper posts? or one of the diodes is shorted? Do these go bad?
Any body have exploded diagrams of this particular column or technical bulletins on servicing it?
Maybe I left out a spacer or something.
