What speed are you seeing it? is that your o2's at wot?ok I'm starting to get knock for the first time after changing the injectors over to the 60s with matching chip i alco installed the hotwire kit
im reading anywhere between 802-826 on my O2's and 1.2-1.6 RD on my Scanmaster DontKnow:
1-2 wot is likely false, 3-4 wot is likely real, did you get your blm's right? what is the boost at wot?, is alky working? if your not sure put some 110 oct. in and see what happen's, with 02's that high i doubt it's lean but check the FP off line vac for the hell of it... a elc. FP gauge is a wise investment, then you'll know if it's rising with boost 1:1That was off the line through 1-2 wot and and 3-4 at wot at about 75
Blm's are okay, put some 110 in to make sure it's false first, i thought Eric had knock ignore below 30 mph on his chips, which one you get?after changing the injectors I'm seeing 119-125 blms not the 116 i use to see constantly..boost is still set with the stock seliniod , what would give the car false knock 1st through 2nd?
5.6 or 5.7 or alky or pump gas, what boost@ timing did it say? if you are running pump gas on fac. boost you will have knock unless you mix it with 110 or add alky, gas these days ain't what it used to be, fac. boost i think was 15-16 psi, you can bypass the fac. set-up with a vac. hose and bring it down to 10-12 psi...I got the street chip
Good idea Jarred...:thumbup:Have you tried adding WOT fuel or removing 3/4 timing via the chip? That is what I would do.
For what you have i would keep it aroun 19-20 max, maybe less..one thing that will affect performance is blowed HG or hole's in the block....i will do so with the timing .. a little 101 on advancing or pulling back timing how does that affect performance?
