adjust your tps if needed. I noticed a good power difference in drivability when those items were done too.
The injector pulse width is changed for the bigger injectors, so the car should have a lean condition based on the new chip narrowing that pulse width for the bigger injector. If he doubled the size of the injector the chip calls for, the computer should be firing the old injectors with half the pulse width it had before, causing a severely lean condition. I think it would still start, or at least try to start but run badly.
adjust the TPS.
yep, it would start, run, then die :chat:The injector pulse width is changed for the bigger injectors, so the car should have a lean condition based on the new chip narrowing that pulse width for the bigger injector. If he doubled the size of the injector the chip calls for, the computer should be firing the old injectors with half the pulse width it had before, causing a severely lean condition. I think it would still start, or at least try to start but run badly.
I'm going to need you to come in on Saturday...:tvhappy:Yeah, uhmm, I'm gonna need those TPS reports. Did you get the memo? We'll send you the memo again.
yeah, just got the new ones on the rail ,fixin to put it back on the motor. by the way , did you get the pm i sent you? didnt know if i did it rightRob did ya get those injectors in??
look at the pic closer, gasket was not centered, leaking vac, that is the way it was installed
10-4, some people should stick to working on weedeaters :arab:So that explains the leak we heard
im currently runing 3 of erics chips an my dad is runing 1 so that is 4 and all 4 cars ran 60% better an idled ALOT better after chip change. You sure you gave him your right specs ?
my 84# injectors idle just like a stock car
and ive had reds chips / joe lubrants chips no coment on his attitude / stock chips / and Eric aka turbo tweak chips
WHAT ? the chip and injectors are from tt, 60 lb, 5.7 chipAre those 84# injectors high impedance, and if not I imagine that your computer's injector drivers have been upgraded? The reason I ask is that I'd like to know where I can have the drivers upgraded on my stock computer to handle low impedance injectors.
i know i have seen these somewhere, but cant find the site, any ideas? :whistle:I would go ahead and get a metal vacuum block, the plastic ones are known for not sealing well around the top of the throttle body and the plastic gets brittle and the nipples break off.
