in need of tta parts
burned tta, in need of any enigine bay parts, need everything aside from the long block, need engine harness,upper intake etc. any leads?
Depending on the parts in question many of them are the same for the Grand National (intake manifold for instance) so I suggest you post over at turbobuick.com as well.
You can use the attached PDF with exploded diagrams to help identify what you are after.
Also if you go to this page (The 1987 LC2 Engine Description Manual - BOC Flint Factory - Turbo Trans Am Forum) you find the Grand National engine description manual that will help identify if it's a part shared with the Grand National or not you are trying to find.
Looks like TURBOGTA is parting out his car....
I have some spare parts, some from a GN. Alternator, turbo cover, hoses, pipes ( both stock and drilled for alky, clamps , etc
exact parts im after are, a engine harness, complete upper intake with all sensors, intercooler pipeing, fan that attaches to the crank shaft.
Here's the TB inlet pipe (or up-pipe):
Original Inlet Pipe 1986 1987 Buick Grand National GNX Regal Turbo No Reserve | eBay
Hoses and clamps you can find from many of the GN vendors (or on ebay).
The intake is identical to the GN, the upper plenum/dog-house is the same however the TTA have the part number cased in a different location.
Fuel rail etc. is the same BUT fuel regulator/injectors are different. Along with the fuel lines (however these been reproduced by classictube.com from a set I had done years ago).
For the sensors on the intake one is different from the GN as we have a temp gauge not a tell tail indicator; do a search on here and you will find a post from me with part numbers and some photos.
The EGR solenoid bracket is also different from the GN.
