I have new door weatherstripping. It appears I need to remove the black plastic on top of the door panel by the window. Can that be removed separately or is it attach to the entire door panel?
so it seems i need to roll down window, remove the black trim around the door pull handle, then pop out the plastic pins around the edge of door panel, then push entire panel up and out to slide it off.
i'm assuming i just need to find the screws for the black trim and pop out the door lock slide. any other screws i need to find before removing the door panel? the armrest itself stay attached to the door panel. i've done this on 4th gen cars many times... just want to make sure i don't break any old parts on the tta.
