we just had a breakthrough
sorry v6ta-mi, i was working on it with my dad all evening.
we were using a test light.
we found that the only way to see what was really happening was to use it with everything plugged in. there are 2 wires going to each headlight motor. when nothing is happening, they are both hot. when the signal is given to raise the headlights, one is hot and the other is not. when the signal is given to lower, the opposite wire is hot and the other is not. ocne the headlamp is up or down, both wires become hot and the motor stops.
at least, thats how it is on the fully functional passenger side.
on the drivers side, both wires are hot no matter what.
when i first connected the motor with the paperclip holding in both brushings, it shorted it out and blew a fuse. apparently those headlamp modules are very vulnerable from what ive read. i likely damaged it when that happened.
Top-DownSolutions.com sells refurbished modules for $60, im gonna have em overnight a couple. from what ive read people posting, they accidentally created shorts when doing this and had to replace their modules, and then everything worked fine. im hoping thats my case, and i can elave this mess behind!
if it doesnt fix it though, look for me in the news because ill probably go temporarily insane, and who knows what will happen then :guns:
