Hard-to-find parts
TTA579
South Bay TTA "Barn" Find
Anyone have a lead on the:
center console compartment light/switch?
hvac/radio highlight lens (lens under the hatch release button assembly, may be the same lens inside the center console)
a spare rear seatbelt trim cover (the big boxy thing, I've broken one)
center console compartment light/switch? - Not sure if I got a spare one or not but will check ... I do believe the 4th gen light/switch also fit but not 100% sure as I've not tried it.
hvac/radio highlight lens (lens under the hatch release button assembly, may be the same lens inside the center console) - Yep they are the same; if you can't find one let me know as I should have a couple spare ... might even be able to deliver in person end of May :D
a spare rear seatbelt trim cover (the big boxy thing, I've broken one) - Don't see these too often for sale ... which side is broken?
I will have to familiarize myself with the local junkyards. Also, ebay because I'm generous. That one doesn't look EXACTLY like mine, but it's close.
Do you have a part number or something, even a proper name. I'm not sure where I'd find one of those. Sadly these things get burnt up with regular use, I'm going to have to see about LEDs to reduce heat.
Yeah, I saw one a few months back and I'm kicking myself for not buying it off ebay. I don't recall which is broken, they were in storage pending carpet install and one of them fell from about 6 feet. Snapped the bottom side in half. Still have all the pieces to try to piece it back together, but it will never truly be the same.
Any time you're in town, drop me a pm or something and I'll see if I can't drag the TTA out of the driveway.
Lens is GM #10035979
Switch/Lamp is GM #25509430 (number of them on ebay if you search using this part number)
