{FS} 1967 Rally Sport Camaro 327 Small Block TH400 85k miles PROJECT---
alwayscode390
Same pics, but bigger here:
http://www.cardomain.com/ride/2248533/1967-chevrolet-camaro
Up for sale is a Classic 1967 Chevrolet Camaro RS Rally Sport.
I can find old pics of the engine after it was freshened up top, and the interior if you guys want to see it ... just email me and ask.
I am the 4th owner of this car, and the car has "been in the family" since it was new. It has spent 34 of its 46 years in Arizona (originally an Arizona car ) and has spent the last 12 years in Missouri. It has 84,000 original miles. Sat for 10 years, then I got it and drove it 2,000 miles over 2 years, and then it sat for the next 10 years.
Its a true Rally Sport by checking the VIN, and came from the factory with the 327 that is in it ( stock block and bottom end ). It was white with a black nose stripe, and a black vinyl top, with a black interior.
Came with 4 wheel drums, still 4 wheel drums.
Rear lip spoiler has been ADDED, was not stock.
It needs a repaint but most of the rust is surface rust BESIDES the drivers lower rear quarter panel from the trunk leaking.
White vinyl top is showing signs of cracking but is still complete.
Window Weatherstripping and window rollers replaced all around.
Needs a drivers side floor pan replacement.
Has a few electrical issues from a bad car alarm (horn, bright lights, windshield washer motor needs replaced, and the drivers door is locked shut from a stuck automatic lock actuator).
The interior is in pretty good shape ... good headliner and is complete. Front black vinyl buckets and rear black vinyl bench. Gray Carpet. Custom door panels (red, gray, black) that are warping. Non cracked dash. Original RS chrome/black steering wheel.
Missing STOCK RS grille and motors, and the AC (the dash has AC vents).
It has been sitting in storage for the past 12 years ... and will need a full fluid flush ( gas too ) , and tuneup stuff ( distributor cap, plugs, wires, and probably a carb rebuild ).
Recent Mods (installed but sitting for 8-12 years):
*Full PST Polygraphite frontend rebuild w/ manual steering rack. (10 miles on it)
*Eiback 2" front lowering springs (10 miles on it)
*Full 2 1/2" header back exhaust w/ Holley Aero Chamber Mufflers(10 miles)
*Topend Rebuild (2k miles on it)
- L79 cam, stock lifters, stock rockers, stock pushrods, and stock fuel pump
*Holley 600 Double Pumper (rebuilt 2k miles ago)
*Rebuilt Power Packer 283 Heads with new valves and z28 spec springs(2k miles) with stainless tall valvecovers
*Billet HEI Distributor (2k miles)
*Steel Motor Mounts (2k miles)
*PAW High Performance Water Pump (2k miles) with new timing chain
*New Stock Spec alternator (2k miles)
*Edelbrock Aluminum RPM Performer Intake Manifold (2k miles)
*Flushed and prodded stock radiator (2k miles)
*4 new brake cylinders (2k miles)
*Hedman Coated Headers that are flaking off and rusting (2k miles)
*BOP Turbo 400 Transmission with a reverse valvebody and a B&M Slapstick shifter (30k miles)
Also has tinted windows and 15" Front and Rear Chrome KMC Deep Dish Wheels (slight rust starting) , and BFG tires all around (brand new but dry rotting).
Stock rearend, not sure of the gears.
This car ran GREAT when it was running. I then parked it and forgot about it .
It honestly should be an easy project for someone who just wants a cruiser. I let it sit because I had "big plans" for it , including a 502 Ram Jet Big Block and a t-56 6 speed. I didnt want to drive it the way it was.
I am sick of watching it age and never finding the time to put into it.
Please NO TIRE KICKERS, I have limited spare time.
You are welcome to come do any tests on the car or get it running if you wish.
NADA is valuing these cars at $13,000 - $40,000.
***AS IS I want $9999 OBO
THANKS for your time !!! ---
price is too high for me ... want to see what you could get for 6,500 ?
68 RS/SS factory big block 68k miles hounds tooth interior second owner ... beside my 99 SS ... my bro sold his plane jane restored 67 for 5k with 327 non posi
Those cars were the deal of the century at $5k and $6500. ... the sellers ripped themselves off. I see plain Jane first Gen shells sell for $7500 all the time on the first Gen forums with no interior / engine / or transmission. ---
guy keeps his 6 cyl shell in our shop ... Ill take a pic he has over 10k in it just sheetmetal from goodmark
I believe it ... but usually with these cars the rate of return is pretty good. You put money into them, you get it out of them.
I bet you could put $25k into a 67 RS camaro and see $15k back when you sell it.
WAY different than a TTA ... you put $25k into it , you would be lucky to see $5k back ... if it didnt DEPRECIATE your car HAHAH ;) ---
Here is the CURRENT Craigslist Ad:
*** THIS CAR IS CURRENTLY A PROJECT CAR ... MEANING IT NEEDS WORK, AND CANNOT BE DRIVEN HOME ***
I am the 4th owner of this car, and the car has "been in the family" since it was new. It has spent 34 of its 46 years in Arizona (originally an Arizona car ) and has spent the last 12 years in Missouri. It has 86,XXX original miles. Sat for 10 years, then I got it and drove it 2,000 miles over 2 years, and then it sat for the next 10 years.
It needs a repaint but most of the rust is surface rust BESIDES the drivers and passenger lower rear quarter panel from the trunk leaking. Also baseball sized rust under both doors.
White vinyl top is showing signs of cracking but is still complete. Rust is showing through the cracks.
Window Weatherstripping and window rollers replaced all around except the back window.
Needs ALL floor pans replaced (all but passenger side front has a hole in them). May as well replace the carpet too while your at it ($250 for pans/ $100 for carpet)
-Both doors will need new manual locking internals ... or you can add a new car alarm with automatic lock actuator control (locks doors automatically when the alarm is armed)
The interior is in pretty good shape ... good headliner and is complete. Front black vinyl buckets with black cloth centers, and rear black vinyl bench. Gray Carpet. Custom door panels (red, gray, black) that are warping. Non-cracked dash with good dash pad (has a dashmat installed). Original RS chrome/black steering wheel.
*Eibach 2" front lowering springs (10 miles on it)
*Full 2 1/2" header back exhaust w/ Holley Aero Chamber Mufflers (10 miles)
- L79 (corvette) 350hp high output cam (222/222 .447/.447), stock lifters, stock rockers, stock pushrods
*Rebuilt Power Packer 283 Heads with new valves and z28 spec springs(2k miles) with polished tall valvecovers
- New Brake Pads all around (2k miles) with new drum brake springs (2k miles)
*Hedman Coated LongTube Headers that are flaking off and rusting (2k miles)
*BOP Turbo 400 Transmission with a reverse valvebody and a B&M Slapstick shifter (20k miles) fluid flush + filter (2k miles)
*4- BF Goodrich Radial T/A Tires with less than 10 miles on them ... but they are dry rotting (holding air). Rears are 275/60/15.
--- Will need 2 front replacement tires ASAP , with a lower profile. These tires RUB (side to side) with the 2" lowering springs installed.
*Stock Oil Pump replaced (2k miles)
*Stock Fuel Pump replaced (2k miles)
*Stock Timing Chain Replaced (2k miles) with chromed cover.
*Kenwood CD Deck / JBL 6 x 9 " speakers in the rear / Kenwood Tweeters in the AC vents up front / "Bass Shakers" under the front seats with a PROFILE Amp
*3" Tachometer mounted on the column, Triple 1 1/2" gauges installed but not mounted (sitting on the transmission hump) Oil Pressure, Water Temperature, Voltometer.
*15" Front and Rear Chrome KMC Deep Dish Wheels (slight rust starting on the lips) .
*All windows have been tinted (20% on the sides , 5% on the rear)
*New Stock Spec shocks up front , Air Shocks in the rear ( 2k miles )
*"Frenched" Antennae.
This engine SHOULD be putting out around 350 horsepower. Has a lot of pep and revvs forever!!! Very fun to drive.
All the dash gauges work.
Will need a drivers side Mirror ... I took the chrome one off to clear the car cover , and I lost it in my recent move (if I find it I can include it).
Stock rearend, not sure of the gears (probably stock ... but may not be since it has a chrome cover).
This car ran GREAT when it was running. I then parked it and forgot about it (focusing on modifications for the future).
It honestly should be an easy project for someone who just wants a cruiser. I let it sit because I had "big plans" for it , including a 502 Ram Jet Big Block and a t-56 6 speed. I didnt want to drive it the way it was ... didnt want to risk wrecking it before I could modify it.
I am sick of watching it age, and never finding the time to put into it.
The great thing about this car , is the money you put into it ... is more money you will get out of it someday. Keeps appreciating in value everyday!!! At this price the value can only go up as you work on it.
YOU ARE RESPONSIBLE FOR SETTING UP A TOW TRUCK TO GET THE CAR HOME. I can bring a battery if you want to test the electrical stuff , but car does NOT come with a battery.
***AS IS I want $8999 OBO
I'm not trying to make any money on this, just trying to recoop most of the money I have into it.
I will be posting videos of the interior/ engine/ and a walkaround outside the car once I get them uploaded to YOUTUBE. Email me if you want them sooner.
