Front seatbelt receivers
TTA984
Does anyone have a good source for front seatbelt receivers, the part that bolts to the floorboard in the front. I found them at one place and they were over $140 for the left and right side. They were new GM nos maybe that is why.
What's wrong with yours?
Ebay would be your best bet (or the NOS set you found and $140-150 seems to be the going rate for NOS).
The plastic outer sleeve is pretty bad and broken, especially the one on the drivers side. Really looks bad. I might try to call that refurb place and see if they can replace the outer plastic sleeve. I hate to buy new ones if this is all they need.
Yep that is what normally goes bad ... I doubt they will be able to fix that as it needs to be replaced and not spare parts (plastic sleeve) would be avalible.
I think you will be better off trying to find a good used set, there's usually some on ebay ... remember both the Camaro and Firebird 88-91 will be the same and correct color (beechwood) for you.
