Hey guys. I just bought a rough '89 TTA a few weeks back and although not abused it was not loved. So, going through it front to back. So far replaced; waterpump, heater core, plug wires, motor mounts, trans mount, u-joints, window tint and tires... I've been restoring old muscle cars for years and have had at least a dozen 3rd Gen TA(s), but this is my first '89 Turbo TA (always wanted one). Also the first one that's had this problem.
I've got a driveline problem: Under acceleration (light or heavy), there is a constant grinding/vibration. Vibrates the car and my belly. Almost like running over a cobblestone road. If you have ever had an exhaust system on a race car get within a 1/8" of the floor pan and it start vibrating under acceleration, you know what I'm talking about. The differance is this is in the driveline..feels like a worn out bear or bearing somewhere. Doesn't matter what gear or what speed. With no acceleration, it's still there, just not as intense. The tires were old, so I replaced them, already did the u-joints..no real change. So, before I start tearing into the rear-end or tranny...would like to hear from folks that's been there done that. Car has 75k miles. Rebuilding the rear doesn't sound like much on this car with the lack of parts available for the BW 9 bolt. Don't want to tear into the tranny, as it appears to be shifting fine, but who knows, maybe the output shaft gears or bearings have gone bad.. I'm just too new to the 200r and 9 bolt set up to know what to look for.
Thanks guys and any help would be appreciated.
