This is a sample guest message. Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
Differential filler plug
M Peter Leifert
Anyone know where I can get the rubber plug in the differential. Mine has a little leak. I'm not sure about pulling the plug because after 36 years it just may come out in pieces. I need one as a replacement. I'm trying the manufacturer. Any other source? Thanks.
Me Again... The gear oil in the differential is the original. I've had the TTA for 36 years and never had a reason to change it. GM specifies lubricant 1052271 which is an 80W-90 GL-4 plus a limited slip dif additive. I assume that the original in 1989 was not full synthetic. Reading a lot of tech comments has me totally confused now. What gear oil do you suggest? The one in the excellent link you sent me shows a 75W-90 plus an additive. I wish I wasn't so dumb about this.
