Dash Harness
Mark Wiggins
With the way my luck is going, I may need a good dash harness. I have to finish taking it apart... Does anyone have one?
Thanks!
Mark
Mark I honk your best bet is to get one from a 1989 GTA that is uncut ... then take the wires for the boost gauge and reuse that ...
As far as I know he harnesses are identical but have not compared in person
Happy to help Mark, I suggest you lay both wireharnesses next to each other when you found one from a GTA then compare ... and would be helpful to others if you could take pictures and document any differences you find (should only be that 2 wire harness but for the boost gauge as far as I know and not sure if that is simply a loose additional wire or if part of and integrated into the rest of the harness
Will 1989 GTA be the only year? I've had one reply from a parts breaker, and he said the the analog was a one year only...
Mark
Hi Mark, I have decided to part out 844. Collision damage was just too extensive with too many parts missing. The dash is complete with factory radio still installed. It should have a good wiring harness.
Mark did you get a dash harness in the end? Would be really interested in pictures to understand and see the difference compared to the none TTA dash harness
