CRANKS BUT DOES NOT START
ratpower
Member
Hi there, Just finished replacing a set of headgaskets and also installed
50lbs injectors. When I went to start the engine all id did was crank.
Checked over everything I may or may not have removed or loosened
and everything looks good. The problem I'm having is no injector pulse. I
have spark, fuel pressure, no codes, good battery, and enough fuel. So I
narrowed it down to either and crank sensor or PCM. Everywhere I read
the plow chart points to ECM. But how could this be if the vehilcle ran
before the repairs. Any help would be greatly appreciated.
