Not as far as I know. That is the port to plug in the scan equip. that monitors the engine (rpm, codes, temp, etc) That is the worst thing about the TTA it is hard to change the chip and get ecm back up in position correctly. Beware static electricity when removing chip.
not sure if i want to use that chip i heard eric has a better chip?? any info would help new at this i want it to run 11's 12's i bought it and i just let it sit for 10 yrs only has 26 k on it
I just ordered this from turbotweak.com.Eric sells a package Set of 6 flow matched 60lb injectors (Siemens/Mototron) with matching chip (TT Classic v5.6) I think the stock injectors are 42lb. What would the 60lb injectors and chip do to a pretty much stock car other than a K&N filter and mod exhaust? Are there advantages to having I am wondering if it is worth it to upgrade the injectors. If you upgrade the injectors, do you have to upgrade anything else? fuel pump???? I am such a novice at this but it is fun learning. Thanks for the help.
