Is the block in the TTA's a 109 block like the Buick GN?
I am hopeing to put a 3.625 stroker crank in.
If the TTA's has the 109 block and I get this crank, what are the dangers, if any?
The cam that I'm putting in is a mild hydraulic roller sreet cam.
Should I worry about anything with the crank and the cam?
It also said the rods was made to fit the 3.8 with ARP 8740 7/16" cap screws. So is that what the TTA's have?
Also does anyone know anything about changing the stock MAF to the LT1 or LS1 MAF? I have seen it on others and wonder what you had to do to change over to it.
