Anybody remove the headlight switch ?
El Dee Bee
I'm trying to remove the headlight switch. It looks like I'm going to have to remove the fusebox to get at it, which might get tricky. Anybody ever do this ?
for the headlight switch (pop up lights) you need to remove the complete gauge plastiuc sournd piece. Screws at top into the dashpad ... screws hidden under the foglight switch pod and the black cover underneath steering wheel so need to remove that as well and there's one hidden under the passanger side dash cover as well (the piece with the Performance Suspension badge on it).
Once all that removed the switch is in a plastic bracket you can screw loose and pop the switch out to repari or replace.
