9 bolt trouble ?
Do you have the part numbers to order from Autzone (bearings and seals), just thought I get the parts in for any future needs :-)
How hard was the rebuild?
Auto Zone Part # Set-9.
You'll need to replace the seals also, available seperately timken part # 710179 for the passenger side (9.99) and 224255 (3.99) for the driver's side.
Save yourself untold grief by NOT going to autozone and order everything from here.
http://ratech.stores.yahoo.net/79bogmax.html
As far as difficulty? the only tough part was writing the check for $438 for labor.
Duanne rebuilt it and said it was relatively easy, not 7.5" 10 bolt easy, but nothing special was needed for tools.
I had him install that pinion bearing shim in place of the crush sleeve. My research shows that is prone to problems with pinion bearing failure.
