20th aniversary air cond. lines
TTA984
Noticed that my air cond. lines at front, near the top of engine near radiator have 20th aniversary trans am on it. Is this the original lines or something else.
Yep they do carry that silver/mirror finish sticker with 20th on them along wiht the line assy part number.
Two versions of that sticker ... one with a 20TA-... part number and the other version with a "proper" 8 digit GM part number. I got pictures of both I can post when I get to it.
Great, so I compare my version to the other one.
So you got the 8 digit GM part number on there then? I'm not sure if that might be a GM replacement part or not as most I've seen are the 20TA-.... version and that is the PAS part number as far as I understand.
Here is the pic of the sticker on ac line.
Yep that is the most common one I've seen ... thanks for the reminder ... photo of the reproduction I hade made for mine next to one (OEM) with the GM part number on it.
Oh and the 3540 on there I beleive is the "client" number and the rest is the part number .... looks like this is how PAS numbered things ... so pretty much everything PAS designed do have a 20TA-xxxx part number then GM assigned their part number to it ... however at the reunion next year I'm sure we get this explained as I'm not 100% sure how it worked at the moment.
