jarredsoon
PLease help.....
My cars batery gauge and the scan master show about 9 volts!!!!
I place a volt meter to the battery and it has 12.5
I check the alternator with car running and it is 14, battery with car running is 14 too.
I probed the harness to the ecm and it is 12.5 with motor off, key on.
Car wont start unless I put a battery charger on it, and then even when it does start the scanmaster tells me the bat is at 9 volts???? But I know the bat has 14 when car running????????
I checked the grounds by the battery and they seem good, grounds to the engine seem good, all tight and clean.????
Please help????
Thanks, Jarred.
Please help????
Thanks, Jarred.
