As stated above I replaced the Temp sensor for the ECM which did not work. It is my undestanding that the other temp. sensor is only for your gauge on the dash and has no effect on any other electrical components.
The reason I asked about the VATS system is the manual for the 89 Pontiac states that the VATS controls both the starter and the signal to the fuel injectors. The way I understand it is the Vats sends a signal to the starter and then the starter ralay sends the signal to the injectors. It does not say if the VATS module has two circuits to do this or if it can crank the engine and not send the signal to the fuel injectors? Or is the starter relay is bad?
