TV-Wire clip (transmission shift cable) to head Q ?
Jan Larsson
Administrator
Staff member
Anyone with a low milage untouched TTA that could see or feel if there's a clip (see pictures) attached to either the head (driver side back firewall side) with a bolt OR if that clip is attached to the top corner (driver side) bellhousing bolt ... OR if there's no clip at all and the cable / wire just runs down to the transmission loose all the way.
The GN's did come with this clip to help routing the cable/wire properly however over time as this clip is a pain in the but to re-attach most people just binned it.
I got the correct clip however not 100% sure if the TTA came with it and if so if attached to the head or to the bellhousing bolt per above.
Any help much appreciated.
Note: the attached PDF with the illustration is from the GN engine manual and shows in Figure 6 the bolt #2 holding the clip to the head looks like and that's what the GN guys (well most of them) confirmed came from the factory.
