pacecarta
Moderator
from full cage race ready to street friendly sleeper
pulled the stroker stage 2 V6 w stage 2 heads and 4" downpipe , th400
in went an 800hp 109 from my 10.0 bracket GN and temporarily a th400 because it was setup for it
reprogrammed the FAST for the new motor and 93 alky and then parked it for over a month
managed to get couple breaks in weather to get back to it
removed the 28-10 sicks and popped on some 245 bfg kdws
replaced the gold bird center caps with WS6 caps
replaced the old spoiler with a fiberglass repop (painted it basecoat)
cut out the roll cage front bars - replaced dash top and removed all previous gauges ,
cut out the roll cage main hoop and rear bars to put the OE seat belts back in after redoing the headliner
removed all the aftermarket audio equipment and wiring
redid dash harness for 22pin radio and installed a delco radio and new plate
removed momo wheel and installed stock GTA radio control wheel
pulled steering bowl to remove a 80s theft collar
then built a 3" external gate downpipe so i could move it around
got it back on the lift and tied it into the 4" cat back..too loud for me
pulled the mufflex 4" cat back and installed a stainless spohn 3" dual outlet cat back
removed noisy weldon 2015 pump and installed a quiet 255lph walbro inline (380lph going in soon)
pulled the hurst quarter stick shifter and installed a stock shifter setup which worked for the th400
reinstalled factory leather shift knob and boot
restored the factory neutral start wiring and backup lamp switch on shifter
fixed the high mount brake lamp with a new hatch flipper contact pad
moved the battery from spare tire well back to under the hood with new cables
put in a razor dual nozzle alky kit , new reservoir bucket and heat blanket
got the chance to do some more so pulled the th400 and popped in 2004r ,changed the slip yoke on the 1350 3.5 driveshaft
installed derale thermo controlled fan cooler under driver seat with 6AN hoses
cleaned up some paint stuff and then installed the pace decals on doors and windshield
and finished up exhaust by making and welding on some custom stainless 3" inlet dual outlet tips like the originals
with hood down walking around car theres really no giveaway about whats underneath except the long 1/2 studs at rear wheels which i plan to replace with short 12mm studs
