Took the tta out today
Quiky One
Silver Member
1.2 miles of fury :worthy: haha
Breaking in the new brake pads and making sure my TQ lock switch worked. Also fixed an alky tank leak that has been there since Ohio.
All I can say is the TTA sure loves the cooler air. Chirps the tires hard on the 1-2 shift at low boost.
Hope to hit the 11's in 4 weekends!!
sverble said:
Eggszellant. Could you not have the lock up option programmed into your turbo tweak chip?
yes you can but I like the adjustablility of a switch. Some cars like it at 80 some at 90 some at 95...some cars knock with it engaged. I didn't want to chance ruining my day of racing if I get knock with it or it bogs the car down. Erics chips lock it during part throttle but no WOT unless you specify.
Jason
I dont run a lockup converter but Erics chip for my car has an adjustable WOT lockup feature. I dont remember the range but I belive it's fairly large. If I eventually swap in a 2004R I plan to take advantage of that feature that I feel will not only give me the best times but also the consistancy I'm looking for.
Steve
Steve
Hmm...I don't think my chip has that feature, but even if it did it wouldnt work. My battery isn't strong enough to hold 12 volts through starting so the changes never save. I am too lazy and cheap to replace the battery. It holds a charge fine and starts the car great. But I plan on figuring out where the car likes it locked and then have Eric burn it for me. That should work good. How far off am I?
For someone who is always saying drive the balls off your TTA yours never seems to move much!! :boxed: :whistle: :fuckkk: :rofl:
I do drive it a lot...to the tune of 1.2 miles since August 18th haha
