R headlight motor spins
fast400
Pressurized
Does anyone else's Headlight motor spin when re-connecting a disconnected battery? Everytime I disconnect/reconnect the battery, my headlight motor spins for 10seconds then stops.??
I had that problem at one time.
It could be your pellets in your headlight are worn out.
Best thing to do is get a headlight rebuild kit from top down solutions,
It is not hard to rebuild the headlight motors, the passanger side is the
easiest side.
easiest side.
The motors are new...the only time the R motor spins is if you disconnect the battery, then reconnect...only for 5-10sec.
