LV TTA#996
Member
I need help!! Here's the scoop- car pops when I get on the throttle, happens at 10lbs of boost in 1st gear everytime. Then, if I get into 2nd or 3rd and floor it, no popping. Connected turbolink, O2 volts are between 650 and 880 at idle, no cross counts (but I just put an O2 sensor in about 6 months ago) When driving, cross counts move a little, but not much and the O2 volts are still high. Car is running rich (I smell the exhaust). Is this a bad O2 sensor (so soon after putting it in without EVER using race gas?) The knock was only 5.4 at its worst, but this came at 3300 rpms. I was getting 3-4 degrees at 2800 rpms, half throttle. What do I do, I checked fp and it is 44 at idle (Thrasher chip for blue tops). Is this a vacuum leak? Bad O2, cam sensor? Help!
Danny TTA#996
Danny TTA#996
