Part name or number
BuickGN
TTA# 130
I'm looking for a nameor part number. The parking and turning lights module that are in the front right underneath the hood screw into the square plastic clips that pop into the sheet metal. I need the name or part number for those clips. I added a laser jammer to the front by buying the extra set of those modules and cutting out half of it in mounting the laser jammer receivers in those holes. Not totally stealth but where else would you put these? I have to be in that same area anyways and when I put on by the fog lights it looks like total crap. Those clips got damaged by popping it on or off.
I think I know what your talking about, the stock ones were small black square-ish looking retaining inserts for the parking/turn signal lights right?
If were on the same page, I went to ACE Hardware, in there massive nut/bolt isle they had GM style inserts like those. I can't remember if they were black or white replacement inserts but they fit perfect , and looked stock, cheap too!!! I would give them a try.
Thanks for the info. We have a Ace hardware right down the street. Just for curiosity do you know what the name is or have a part number?
Should be 3999700 (NUT RAD GRL EXT TO HDLP) ... discontinued a number of years back unfortunatly ...
I don't know he part numbers off hand. At Ace, the inserts were with the license plate/body stuff in there nut/bolt isle. As for the original numbers from GM, I don't know, but they are discontinued.
QUOTE]
I went back and looked at the clip and it doesn't look like the plastic clip is square, just the sheet-metal indent is square? I have the two broken pieces and that doesn't look square either? I known GM doesn't sell them but I think I can trace down an exact replacement probably from where GM got them from or a similar source.
They are oval, somewhere I got pictures of the new ones I got for mine years ago ... not at home until next weekend so can have a look then. I bet AuVeCo to someone got something similar that will work ...
yes, the main body is oval in the top is round. That's exactly where I found the exact duplicate. Must be where GM gets most of their Fasteners from. The website clips and fasteners sells their products. I'm going to order a bag and see how they work out.
