NO start
tta299
White Car Fever
Car starts fine sometimes and dosent start other times. Any ideas ? It wont even turnover with a full charge
I had a similar problem with my first tta. When warm, it would not crank. It was the alarm starter disable feature. It was right on the area where they cut the wire to bypass it to the relay. Hope this info helps.
Good luck!
Sounds like the "starter wiring" issue where the power wire going to the starter isn't carrying enough voltage. There are many posts about it on turbobuick.com in the turbota section. There is a "hot wire" how to on there as well.
Good luck.
