New Member in need of torque ladder Bracket
Anyone know of a salvage TTA or removed your factory torque ladder(that long bracket next to the drive shaft. I need the piece that sandwichs the end of the torque ladder near the yoke of the tranny. The part that mounts to the trans craddle is fine but i damaged the piece that removes(held in by one bolt and a ear at the bottom.
I'm guessing from the description you're talking about the transmission mount, where there's 2 bolts into the tranny and 1 bolt into the crossmember I believe. They make stock replacements that you can get at Autozone I believe.
Detroit3point8 you might want to try and see if one from a regular thirdgen will work, the torque arm brackets are very similar in that they sandwich the bushing/torque arm and one bolt holds it together. The part that attaches to the trans cradle is different than the part that would normally mount to the trans tailshaft but the other part looks like it might work. Remember there are very few parts that are actually TTA specific, alot of the car is the same as a V8 GTA or any other thirdgen for that matter.
HTH,
Steve
The one from a 4th Gen (manual transmission) is the same (at least 99%), I use that on mine and works fine ... I can find the part number when I'm back home for you if you drop me a line to [email protected] and remind me. Took me ages to find one that worked in the meantime I had one fabricated to fit.
