Injector R&R?
olddude
I have both the Factory service manual and the supplement manual and I can not find anywhere were it describes how to remove and change the fuel injector "O" ring. Would someone steer me in the right direction please? Thanks
It's in the supplement manual and means removing the "U" shaped fuel rail that all 6 injectors and regulator are attached to.
An easy job to do,maybe an hour or two if you're picky. Injectors will come up out of the manifold and dangle from the rail. Pull injectors out of the rail with rail upside down on the bench. Reinstall injectors with O-rings lubed with motor oil on each O-ring and re install.
But it's in the supplement manual...maybe under "fuel systems"
In my service manual supplement the fuel rail and injector R&R starts on page 6E3-C2-6. I just put new injectors in my TTA last weekend, and drove it for the first time this summer.
