I decided that since the front wheel bearings hadn't be repacked for the time I've had the car now (over 2 yrs) and who knows when before that....it would be a great day to repack the front bearings.
I follow my normal procedure for doing this, but ran into an odd problem. Whenever I hand tighten the nut I could feel notable play in the disc if I wiggle at the top and bottom. The only way I could eliminate play is to torque to the 12ft/lbs and leave it there. Is this a sign that my bearings are shot. They looked good visually.
(My bearing procedure after repacking: 1. Torque nut to 12ft/lbs while turning disc. 2. Back off 1/4 turn. 3. Hand tighten, then align to the cotter hole.....this procedure usually works fine.)
