roadkill73
I installed a Walpro and hotwire kit two years ago. Car isnt used much.
Got into it today, turns over but wont start. I turned the key to the on position and cant hear the fuel pump running.
Before I decide that its the fuel pump gone bad. Can anyone tell me what else to look for as to why its not running
Such as fuses and where would the fuses be located.
I did check the fuse for the hot wire kit and its ok.
Also, when I turn the key to the on position, I hear what sounds like a click noise somewhere below the MAF.
Any help or suggestions would be greatly appreciated.
ALSO, is it possible the hot wire kit goes bad and would cause the pump not to run ?
__________________
__________________
